Replacement Belt
Discussion in 'The Garage' started by deadguy, Feb 27, 2006.
  1. deadguy
    deadguy Registered Member
    Feb 5, 2005
    21
    seattle
    Ok I have a 1996 3/4 to 4x4 suburban with the 6.5 I have tried belts from Shucks Autozone Napa and the Dealership and the all seem to wear out in less than a year. I need help I want the toughest belt on the market.
    Any ideas? Thanks
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I've been told Goodyear Gatorback belts are the best available, and I'll be putting that to the test soon.
    Double-check your pulley alignments - if they are not parallel to each other, you're causing excessive heat and wear of the belt. Adjust and shim as required to get your pulleys parallel with each other.
  3. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    sounds like you have a problem with pulleys, not belts
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    chech the tensioner and idler pulleys, any of them can wear out a belt quickly...I like Gates belts
