replacement cat converter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jacksprat1599, Mar 28, 2004.
  1. jacksprat1599
    jacksprat1599 Registered Member
    Dec 13, 2003
    99
    Austin Tx
    I've got an exhaust leak that needs to be repaired and have considered redoing the whole system.I wanted to know what you guys are using for cat replacement and aftermarket muffler(s).I want to stay single exhaust with a mellow tone, nothing too loud.I'm sure its the original cat and since its on an 89 350 sub with 160k I'm sure its lived its life but even if its still good I was hoping for a better flowing model. thanks
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I'm running dual catco cats from summit racing. I think they were about 50 clams each...Oh and whatever you do don't go to Ed's mufflers up off of Lamar. That guy wouldn't know an exhaust system if it bit him in the ass. If you want to see his handiwork you can check my K5. If I were you I'd take it to Muffin on Burnet... /forums/images/graemlins/grin.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would just like to make you aware that it is against federal law to replace a functioning catalytic converter.
  4. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    thanks for the shop info blazerguy and also what kind of mufflers.
  5. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    how do you know if it is functioning and I don't plan on removing for good just replacing with a higer flow model
  6. NetBlazer
    NetBlazer Registered Member
    Apr 23, 2001
    90
    Littleton, CO
    BS.
    If the vehicle in question has more than 50K miles, it is perfectly legal to replace the cat.
    You can also legally replace it, if it is damaged /forums/images/graemlins/whistling.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    BS.
    That is not true. It is illegal to remove a functional catalytic converter.
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Never heard of that one, /forums/images/graemlins/thinking.gif i have heard that is against the law to replace a cat with another used one, you can replace it, but it has to be brand new.
  9. fjleiter
    fjleiter 1/2 ton status
    Feb 13, 2004
    278
    Palmyra, NY
    Both are correct, It's illegal to remove or replace a fully functioning cat UNLESS vehicle is over 50k miles and there is a documented reason for replacement (those in the rust belt are in luck, just make sure the right parts break "due to rust" when you replace your exhaust...) under 50k miles and it can only be replaced if damaged.
    On the down side, as far as Blazers go it is totally illegal to switch over to a true dual exhaust even if you install dual converters, has to stay single cat. Your only allowed to swap to duals if the vehicle model for that year or later years was offered with a dual exhaust with dual cats which as far as I know the K5 never was. Not sure about the newer Yukons etc but those wouldn't count anyways..... It's also illegal to remove the cat from any vehicle even if the vehicle is never to be used on-road again (ie: making a full-offroad non-street legal vehicle, you would still have to keep the cat on it or your breaking the law)
    BS.
  10. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    due cats still function after 160k or do the clog.I had a freind whose 97 dodge cloged the cat at 65k.
  11. 4xcrazy
    Oct 31, 2003
    9,472
    5
    I have 210,400 sumthin miles and still runnin the original huge fat cat. /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Cats are designed to last the life of the vehicle but don't always. As long as you can justify why you changed your cat it probably isn't an issue.
  13. 89fullsiz
    89fullsiz Registered Member
    Mar 23, 2004
    96
    Portland, OR
    It really depends on where you live. There are federal and local laws. The ones here quoted here are federal.
    Here in Oregon they are not really inforced in fact if I could get my truck to pass a roller sniffer without a cat then I could get by. In Cali and Fairbanks, AK (where I'm from) they do a thorough inspection. Anyways I'll stop rambling!
    at 160K you shouldn't have any problem replacing the cat and probably wouldn't be a bad idea. The above mentioned Catco is an EXCELLENT choice and is a great price. There was a test done on cat flow numbers and it ranked very high second I believe above alot of expensive ones!!!
  14. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    In Cali the replaced Cat has to be in the exact same location as the stock unit too /forums/images/graemlins/eek.gif
  15. bushmaster
    bushmaster 1/2 ton status
    Jun 1, 2003
    146
    ct
    flow master 50 series or there big block series or edelbrocks new muffler sounds nice and looks well made/heavy duty.
  16. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Yeah, well when there are no cats to begin with(PO), my options are limited... [​IMG]
    Fjleiter(sp?) is right on the money about changing the exhaust. My truck has true duals on it and it's not exactly legal but it doesn't really matter...not until the smog checks start here(about 1 year). Not worth going to duals anyway, IMO.
    BTW I'm running Warlock muffs, don't get them, they suck...
  17. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    Thanks for wheiging in everyone.Aren't 50 series flowmasters designed to be duals and if not would a single 50 be too loud? I only want deep mellow tone nothing too loud. I have read a few things about the 70 series here, does anyone like them and how loud are they. to give you an idea what I'm looking for as far as volume I would like to be able to just hear what the engine is doing but then be able to turn the radio on at moderate volume and drowned the exhaust note out. thanks
  18. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Nah, the 50 series(3 chamber) aren't just a dual muffler. I think the 50 is just what you want, maybe a little louder though. Do you have doors, carpet, top? The 70 series are the quietest, close to stock....
  19. bushmaster
    Jun 1, 2003
    146
    ct
    50s have just a nice sound idle and when on the throttle with cats they will be even quieter while your at it install a x pipe or cross over pipe they will mellow the tone even more
  20. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    50's have a nice mellow tone, as well as MagnaFlow Mufflers. Both are good mufflers. Converter wise Eastern and MagnaFlow make good converters.
