replacement doors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nickstegeman, May 20, 2003.
  1. nickstegeman
    nickstegeman Registered Member
    Dec 11, 2002
    38
    Dallas, Texas
    Please Help!!!! I am new to ColoradoK5 and need some edvice from you old timers. I have an '85 rig that needs new doors. Any Suggestions??? /forums/images/graemlins/1zhelp.gif
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    Don't get the cheapo $100 aftermarket doors. They don't have the same body lines as the originals, they're thinner metal, and some of the mounting holes (window mechanism, door lock, vent window) didn't line up correctly. That's been my experience. The other option, if you want new doors, is to pay $550 to GM for the originals /forums/images/graemlins/shocked.gif Your only other option is to find used doors.
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    bone yard.
  4. getitup
    getitup Registered Member
    Apr 27, 2003
    35
    Hazelwood, MO
    Yeah I am having trouble finding doors for my 75 cause the whole top comes off and there is not a whole window track. The scrapyards have all been picked clean around me. I have found newer doors. If I hack off the part of the door that I dont need can I use them?
  5. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    You will need to get the little pieces that are welded inside the doors to hold the weatherstripping on the end-caps of the door.
    UNless your not into weatherstripping... /forums/images/graemlins/rotfl.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, that's how they did it at the factory. GM never made a "special" door for the '73-'75 K5's. They just took a band saw to the standard truck doors and welded in a piece to hold the top plate place in place and strengthen the door after the upper section was removed.
  7. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    I actually just bought a set of aftermarket doors from Interstate Auto in SLC, UT and paid 105 for both (dealer license= no tax and wholesale cost) Body line lined up perfect, metal may be thinner but they come with a 7 year rust coverage, only thing wrong was they missed drilling out the top front screw hole for the wing windows, this compared to a 150 a piece for "descent" doors from salvage. I am pleased with them. My buddy owns a rebuilder lot and all he uses is aftermarket, alot of times they fit better than stock.
