replacement exhaust system
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scrappyk5, Jul 16, 2004.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    does anyone know where i can find a kit that comes with everything needed to replace my exhaust system on my
    1984 k5 305 ?.
    i am talking from where it bolts to the manifold then all the way back to the tip. just stock.
    anyone ?
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Scrappy, I can set you up, shoot me a PM. I carry performance and OE exhaust /forums/images/graemlins/waytogo.gif
  3. dyeager535
    26,979
    I believe this is the right URL...
    rock auto
    However, I checked into pieces for my system (I have the stock diesel duals) and they were outrageously expensive, compared to what you can have bent up, or even make yourself. Not saying they are ridiculously priced, since they are the ONLY ones I've seen that seem to sell "stock" replacement pieces.
    My parts manual doesn't go back to 1984, but unless there were changes in a K5 exhaust between '84 and '86, I can probably supply you with some part numbers. No telling if they are good still, and more than likely, just as expensive as rockauto.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    You really should swing by a couple exhaust shops for quotes, too. I had a complete system bent up for a few years back that cost me less installed than doing it myself would have been. They get the tubing and stuff really cheap and bend it up real fast.
  5. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    mudfrog gave me real good prices on all parts neened
    to put back to oem , but i am going to this one shop on
    monday to see if they can fix the mess first.
    the p.o. really made a mess of it with flex pipe and coat hangers . /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  6. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Don't you know the ridges in the flex pipe help extract the exhaust gasses from the manifolds and the coat hangers will last a lot longer than the factory style rubber bushings. I can't believe you're going to tear out such a sweet system for a stock setup /forums/images/graemlins/wink.gif
  7. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/rolleyes.gif
