Replacement Rocker Panels from JCW
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by swilson, May 28, 2003.
  1. swilson
    swilson Registered Member
    Mar 6, 2003
    18
    Amarillo TEXAS
    Has anyone else used the replacement rocker panels from JCW? The outers are great. Made in canada, heavy gauge, and the lines match.
    I also got the extended inner rocker panels cuz I had some floor damage also /forums/images/graemlins/rolleyes.gif. They are supposed to do the inner rocker job and fix 3" of floor panel. Couldn't figure out how that was supposed to happen. I couldn't get them to work correctly so I swapped the sides and did a little cutting. That did the trick /forums/images/graemlins/thumb.gif.0
    Guess the old saying....Cut to size--file to fit...is true. Which JCW would add an instruction sheet or something. This is the first time doing body panel work and i'm making it up as I go. /forums/images/graemlins/rolleyes.gif.
    I would add a pic of the panel but I don't have a dig. camera or a scanner either...srry. /forums/images/graemlins/angryfire.gif
  2. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I bought some a while back from a local place and had the same problem...I couldnt seem to figure out how they wanted it installed ???? After a little frustration and another beer I fabbed it up...
  3. jhrody
    jhrody 1/2 ton status
    Feb 16, 2003
    129
    Elmhurst, IL
    I put a couple on my old '78 Blazer. I never even primed or painted them, but they held up for the 10 years I had the truck.
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I got the inner and outers from JCW. I like them. Fit pretty well, to make life easy I had the fenders and doors off (I was replacing the fenders also). After everything was done I got looking around and there where several spots that where open or had gaps between to two pieces of metal (maybe I installed the inner wrong).
    Anyhow, here in Indiana that would be a salt collector. So I took a can of expanding foam (it said to seal out water /forums/images/graemlins/rotfl.gif) and I filled the entire rocker panel /forums/images/graemlins/thumb.gif. Once it stoped expanding I cut off the extra and used the duplicolor spray can bed liner on the under side of the truck. Not only do I sleep better knowing water can't sit in there but you can kick the $hit out the rocker and it SOLID! /forums/images/graemlins/rotfl.gif
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Close; "Cut to size, beat to fit, paint to match"
  6. dremu
    Feb 27, 2000
    15,966
    457
    East of San Francisco
    "Measure with a yardstick, mark with an axe, cut with a chainsaw."
    As opposed to the redneck torque wrench: turn it till it breaks, then back off half a turn.
    -- A
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    /forums/images/graemlins/thumb.gif I have a calibrated elbow
