Replacing 12 bolt yoke
Discussion in 'The Garage' started by inscape, Oct 30, 2003.
  1. inscape
    inscape Registered Member
    Oct 30, 2003
    82
    Washington
    Hi, I was wondering if anyone has replaced a yoke or the seal before. Is it an easy job where all I have to do is unbolt the center nut on the yoke and slide it off and put on a new one, or is it more complex than that?
    Thanks /forums/images/graemlins/k5.gif
  2. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    That's about it. Might need a puller to get the yoke off.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i just took the nut off of mine with an impact gun, but decided not to change the seal after all, the yoke slipped right on and off, i also reinstalled my yoke with just the old crush sleeve, old nut and an impact gun...usually if you just re-torque to 180-185ft lbs you dont have to worry, use loctite on the nut...
