Replacing 87 700r4 with a 88 t400
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rooferbret, Nov 22, 2004.
  1. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    My Jimmy is an 87.
    Are there any issues with the computer and or the connecter that plugs into the 700r4 when swapping to an 88 t400?
    Any help much appreciated.
    Thanks, Bret.
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    You should get a chip that came from a TBI with th400.
    The following is AFAIK /forums/images/graemlins/smile.gif
    The only wire used, from the 700, is the TCC wire, The High Gear wire is not used... TCC wire goes to a relay and then to the th400 for its kick down input.
    You could get a foot pedal kick down switch, as well. If you do, I would still get a th400 chip.
  3. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    Seems simple, Thanks for the info.
    Bret. /forums/images/graemlins/waytogo.gif
