replacing a 205
Discussion in 'The Garage' started by Jishory, Oct 14, 2005.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i have never replaced a 205... how the hell do you guys lift these into place? they are super heavy/akward. :o
  2. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    there not as bad as a 203, tranny jack works really good. floor jack and a buddy helps too.
  3. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    2 guys and a floor jack worked for me.
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    bench it, pansy :p:
    actually, I put one in my truck for a mockup fit by myself. I set it on a milk crate and then slid the crate under my truck, then lifted it the rest of the way and bolted it up.
    while that was tons of fun, my dad got a sweet lo-pro motorcycle jack that I will have to borrow for the final fitment.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    We have a tranny jack at work and a lift, thats the best. However, being as you prolly dont have those, I second the bench press method. My friend benched mine in and my blazer was on 12" of lift and 42's, lol.
  6. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    tranny jacks are good. I've used a come-a-long to get them in before as well. it's a balancing act with the come-a-long, but when you need to do it, you do it.
  7. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Cheap motorcycle jack from autozone and a tie down did the job a few times here.
  8. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Use a couple of ratchet tie down straps,from one side of the frame to the other side
  9. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    I just had my brother bench press it up and hold it while i bolted it in. I tried doing it myself for a day with a couple of floor jacks... i could get it up there but i could never keep it balanced :haha:
  10. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    I thought the standard method was to press it up with one hand while you bolt it up with the other :confused: :haha:
  11. diesel4me
    Jul 24, 2003
    17,540
    925
    Massachussetts
    jack it..
    I use my floor jack with a tranny adapter in place of the "saddle" ,and I always strap or chain the transfer case to it,so when it tries to slip off (and it always does!) ,it wont make my skull look like a pumpkin the day after halloween.. :crazy: :p:
    ..NP205's and 203's are HEAVY!..I can bench press a NP208,but can hardly drag a NP205 around on the ground,never mind lift it lying on my back under a truck...one guy I know used an inner tube sandwiched between 2 pieces of plywood to "air jack" his into place!--I told him good luck,hope the tube doesn't POP when its almost high enough to put it in! :screwy: It worked,but I don't reccomend his method by any means.. :eek1: :crazy:
  12. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    I use a cradle that sits on the jack. It is custom made to fit the NP205 and NP203. The NP205 can not be benched presseed.
  13. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    The NP205 can not be benched presseed.[/QUOTE]
    :haha: Maybe not by you....
  14. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    It only weighs ~130 pounds. I can easily carry one around 2-handed. If it weren't shaped so oddly, I could pick it up one handed. :confused:
  15. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    Well if a 205 cant be bench pressed my brother is god :haha: He pushed it up.. slid it onto the output shaft and i bolted it up lol.. :wink1:
  16. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I hope I can locate a couple of you big boys when I put my doubler in next month!!! :bow: :bow: I'm not even thinking of putting this heavy thing in by hand.
  17. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
