replacing a lock cylinder HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ramjet gmc, Oct 27, 2003.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Can someone guide me to a link or write up on replacing a lock cylinder on the column on a 86
    Or I have a 89 column are the plugs compatible
    thanks you /forums/images/graemlins/grin.gif
  2. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    It's pretty easy really.
    1) Pop the cover off the steering wheel center
    2) Remove the steering wheel nut and steering wheel
    3) Use a lockplate puller (free rental at Autozone) to depress the lockplate until you can remove the snap ring around the center of the steering shaft.
    4) Lift out the lockplate
    5) See the small screw head in the hub just above the lock cylinder. Remove the screw. The cylinder will pull right out.
    6) Insert your new lock cylinder and replace the screw.
    7) Reinstall all your parts and youre done!
    Good luck.
    Jeff
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    use a balancer/pulley puller to remove steering wheel do not hammer on steering shaft
