Replacing a NP203
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ankarback, Oct 20, 2003.
  1. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    I´m thinking of replacing my NP203 t-case with one in better shape and have a question.
    How is it connected to the TH350 ? Is it splines or is it bolted on ? I´ve looked in both my Haynes and Chilton manuals but they don´t describe that.
    Is there anything else you have to consider when you´re replacing it ?
    /Johan
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    It has about 8 bolts that hold it on to the adapter. The input is female and goes right on the output shaft of the 350. If your replacing it with another 203 shouldn't have many problems. Probably hardest thing will be getting up there. Its one heavy sob.
  3. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    OK, thanks for the info /forums/images/graemlins/thumb.gif. Yes, I know about the weight. I have to find something strong and high enough to lift it up.
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Tranny jack /forums/images/graemlins/thumb.gif Can probably rent one for not too much $$$
  5. grunt11b40x
    grunt11b40x 1/2 ton status
    Mar 1, 2003
    124
    winston salem, nc
    I just swapped out a 203 and used a atv/motorcycle jack plus some wood to level it. took me about 2 hrs to drop the bad one and mount the good one.
