Replacing backseat roll-up side window glass on Suburban
Discussion in 'The Garage' started by PonchoCatalina, May 16, 2006.
  1. PonchoCatalina
    PonchoCatalina Registered Member
    Feb 8, 2005
    18
    College Station, Texas
    Has anyone replaced the backseat side roll-up window on a Burb? I came out this morning to find that something had struck the window and cracked it from top to bottom. I can get it replaced for $173, but my neighborhood salvage yard has it for $35 - I'm inclined to tackle the job if I'm able. Any tips or input are appreciated. Thanks!
    - Ian
  2. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    Make sure you get the right one, I had a slightly different model and had to change all the mechanicals due to the differences
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    its pretty easy as long as you pull the metal window track with the glass. A helper can make it go smoother too...
    I would just go to the junkyard with required tools (i think its like a screwdriver and a 3/8" socket driver/combination wrench - check for yourself) and tear one apart out there. its pretty easy to do, the hard part is extracting the glass without breaking it by yourself, the helper would be great there.
  4. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    It's easy do it...
    that's all.
