Replacing bad parts=Runs worse
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mountainexplorer, Dec 3, 2002.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I just took a Holley carb off a 454 motor, since it wasnt running right. I put on an Edelbrock which ran PERFECT on another 454 I had.
    When I first started it with the Edelbrock on, all it did was backfire and shoot flames up. Eventually I got it to run and idle. It didnt seem to change much, and it still had a dead spot in it. So, I looked at the plugs, which looked very worn. So I replaced the plugs.
    Now, it dies all the time. It still pops back through the carb, and when I try to drive it, all it does is sputter, hesitate, and lack power. It ran better with the junk plugs and Holley carb that needed a rebuild.
    I hate it when replacing bad parts with good ones makes something run worse! /forums/images/graemlins/angryfire.gif I cant even drive it now. /forums/images/graemlins/angryfire.gif
  2. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    Does this motor have a centrifigal advance in the distributer? Sound like mine did when the weights rusted up and were stuck in the advanced position.
  3. mountainexplorer
    Nov 14, 2001
    4,903
    It's an old points distributor (1973) that looks to have an electronic conversion. There are wires coming out from the base of the cap.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Your problem is in the distributor.
    You said you took the carb off an other 454 that was running good, swap that distributor out and see what happens.
    /forums/images/graemlins/thumb.gif
