Replacing Ball Joints on 87 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JaymzLD, Jun 17, 2003.
  1. JaymzLD
    JaymzLD Registered Member
    May 22, 2003
    11
    St. Louis, MO/Laramie, WY
    I need to replace my front axle ball joints on my 1987 Blazer to pass the safety inspection. I NEED to replace the right lower ball joint, but do you think I should replace all of them in the process? What kind of tools are needed for a job like this? Im sorta new to working on cars and want to improve my skills which is why I bought the Blazer since its easy to wrench on. Anyway, should I replace all of them and what kind of tools are needed? I will probably replace all of them, but want some more info before I do. Thanks.
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Do them all, you're going to need to have the axleshafts out to do it anyway, might as well get it all over with.
    Tools would be a ball joint press, big hammers, large (1", 1 1/8" or so) wrenches, spanner wrench (or a 1" wide file), Pickle forks, snap ring pliers, 4 prong hub socket...
    Getting them out is probably gonna be a lot of fun. Soak the hell out of them with PB Blaster penetrating oil. Dis-assemble the ends of the axle down to the bare knuckle, including removing tie rod. Remove lower ball joint nut, loosen upper ball joint nut and even it out with top of ball joint stud. Use pickle fork and hammers to beat the knuckle off the axle. (may take a while) Once off, (Driver's side, you need to remove the steering arm to use the ball joint press) remove snap ring from bottom of lower ball joint. Press out with the press. Press out the upper ball joint. Get new ball joints, (Grease upper with fitting then remove fitting and replace with the plug). Install lower ball joint first. Once presssed flush, install snap ring. Press in upper ball joint. With spanner wrench, remove adjuster nut from the axle (In the threads where the upper ball joint mounts) replace with new. Install knuckle and use adjuster nut to dial in pre-load. Once dialed in tighten upper and lower ball joints to torque rating in manual. Re-assemble. Take for an alignment as soon as you're done.
    Just do one side at a time to keep it easy, so if you mess up, you can just look at the other side. Good luck! Took me a whole day to do this with air tools... /forums/images/graemlins/thumb.gif
  3. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    BTW, get the joints from Auto Zone. They sell the Dana Perfect Circle joints, worth the extra cash. Make sure they mark the boxes on which is the upper and lower. /forums/images/graemlins/thumb.gif
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You don't need to use a press or pickle fork or anything except a hammer to get the knuckle off the housing. Remove both the upper and lower nuts, take a big ass hammer and smack the $hit out of the top of the upper ball joint. With a big enuff hammer, most of the time the knuckle will fall right out onto the ground with one good whack. It doesnt matter if you mushroom the top of the ball joint with the hammer- You're gonna replace it anyways. So don't be bashful- Hit it as hard as you can. It wouldn't hurt to hit it with some WD-40 or PB Blaster though. /forums/images/graemlins/thumb.gif
    He's also gonna need the special ball joint socket to get the adjusting sleeve out of the ear on the housing. You can use a screw driver or chisel to turn it out, but you'll need the ball joint socket to set up the new one properly.
    I agree with buying your ball joints at autozone- Dana/Perfect Circle parts, and they come with a good intruction sheet with torque specs.
    Hehe- Not to show off or anything, But I can do ball joints in 3 hours max, w/air tools. From start to finish. Thats complete and driving down the road in 3 hours. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  5. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    just wonering, if you don't dial in the pre load what will happen? I installed 4 new ones a month ago, and used the old sleves. /forums/images/graemlins/confused.gif everything seems alright though.
    Thanx
    jeremy
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You will also need the big hub socket to remove the hubs, you can get it at any good parts store. Also while your in there I would go ahead and replace the axleshaft u-joints.
  7. Nikk
    Nikk Registered Member
    Dec 16, 2002
    34
    Lacrosse, WI
    All great info from above. I just wanted to add that I made my own ball joint sleeve tool by welding some tubing of the right diameter to an old socket, and then ground out the areas that need to be removed to create the notches. I've used it twice so far and it has held up great. Just remember if you start making your own stuff start adding extra time to what ever your doing. This job isnt hard in my book but it can be time consuming depending on what you run into and your experiance. I too used to Dana/perfect circle and have had no problems since. Also, they were a little cheaper than moog, and like said above the instructions had alot of info in them. Good luck and if you have problems were here for ya /forums/images/graemlins/thumb.gif
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Thanx
    jeremy
    Why did you use the old sleeves? New ball joints come with new sleeves, so there's no reason not to use them. What would happen? I would think it would shorten the life of the ball joint considerably.
  9. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    You can also make that socket with a deep socket, 13/16 I think. /forums/images/graemlins/wink.gif
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Special tools:
    1-5/16" socket. I have only seen them in 3/4" drive so you will need an adapter if you do not have a 3/4" drive ratchet/torque wrench.
    Hub Socket
    4 prong spanner socket for the adjuster. I made mine out of a deep impact socket and my die grinder. Took me about a hour to make including driving to home depot to buy a cheep socket. Alot better than the hour I spent calling parts stores asking for it!
    If you don't want to mess w/ removing and replacing the ball joints in the knuckles you can take them to a shop and have them press them in/out for you.
  11. foxman
    Oct 22, 2001
    251
    Detroit MI
    I couldn't find a tool to get the old sleves out and nobody from my area had ever heard of such a tool in any of the tool stores. Even the auto parts store I work at where I got the ball joints had no such tool, so I figured that not changing the old one wouldn't hurt it, seeing as I could find no vissable dammage. I hope Ithat you can't over-tightnen these things cause I troques them dowm pretty good.
    /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
  12. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    You can overtighten them...they strip fairly easily, I hear. /forums/images/graemlins/eek.gif /forums/images/graemlins/shocked.gif You'd be able to tell though, so I think you're ok.
    Instead of buying a 3/4" adapter, just go buy a huge 1 5/16" closed end...probably be cheaper, and that's what I used.
  13. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Not that it matters but they do sell 1/2" drive sockets that go to 1 1/2".
    Cornwell is where I got mine.
  14. pfloydmaster
    pfloydmaster 1/2 ton status
    Mar 30, 2002
    156
    Grottoes, Virginia
    Try this:
    Ball joint socket
  15. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Where is Executioner when you need him. He only posts every few months now. Go and search through his posts on ball joint preload. You will find alot of good info if you dig for it.
    You need to have the preload set correctly or you will wear the joints out in short order.
  16. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    All the torque specs and procedures for settingbthe pre-load are listed on the intruction sheet that comes with the Dana/Perfect Circle stuff from Autozone. /forums/images/graemlins/thumb.gif
  17. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Hello Dan, yo the man !
    But if he can't find the tool,, and the Auto parts
    stores don't know of it , then it just does not exsist ?
    Looks like its a Snap-On Tool.
  18. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I thought this one would catch your eye.
    I looked at mine the other day. I used a 11/16" deep impact socket. I then ground it away till I had 4 prongs sticking up that would fit into the adjuster. The inside of the socket wouldn't clear the ball joint stud (but the OD was fine) so I just ground it till it fit. If you can find the tool by all means buy it. If no one knows what you mean when you say "spanner socket" just walk out the door/hang up the phone right then.
