Replacing ball joints?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Feb 20, 2002.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    I need to get all 4 ball joints and both tie rod ends replaced. There's a shop locally that does a great job, but I don't really want to pay the $500 they will probably want for labor. How hard is it to replace them? I caught a glance when my friend was working on his K10, but didn't really get down and look. I'm just looking for a way to save a little cash. Any kind of comments would be appreciated. Thanks!
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
  3. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    I just bought the Ball/U joint clamp/press from Harbor Freight $30. I am going to attempt to do this job myself while I am waiting on the axle work that needs to be done
    "Whatever happened to my Rock N Roll?"
    IM nOt wEiRd, i jUsT lOvE tHe sHiFt kEy!!
  4. Mobile_Mechanic
    Mobile_Mechanic Registered Member
    Jul 17, 2001
    88
    Phillipsburg, NJ
    Might as well do the u-joints now while it is apart, no?
    '84 K30, 6" suspension, 3"body, 350, 350, NP205
    D60, 14 FF W/Detroit, 4.56 Gears, 35" Ground Hawgs
  5. StonerK5
    Feb 13, 2002
    183
    Phoenix Arizona
    Yup those too, and maybe the brakes, repack the bearings...
    Oh man my mind is racing!!
    Main thing I think is to just get in there and check everything out for myself. I hate paying for labor unless it is absolutly nessesary
  6. Mobile_Mechanic
    Jul 17, 2001
    88
    Phillipsburg, NJ
    It is a pretty straight forward job. I would invest in a good manual if you've never done it before. The last ones I did, the hardest part was seperating the spindles from the knuckles.
  7. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    No way would I pay $500. I've done this job myself using a Haynes/Clymer manual, and I rented the special tool to press out/in new ball joints from AutoZone. Since yer gonna have to tear the whole front axle down, now is a good time to check u-joints, bearings, and grease everything up etc. It took me a whole afternoon to do the job myself. I did this on my GM 10 bolt 9 years ago. I inspect and grease everything at least once a year and after every off-road trip, and those ball joints still have no slop in them (I used Moog). I just performed the same job on my Dana 44 front axle for my Willys last fall. The job is well within the range of the DIY.
    [​IMG]psychoholicslag
  8. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It was an all day job but I took my sweet f'ing time doing it. When you remove the knuckles dont be afraid to swing the hammer, you're gonna toss the old ball joint anyway. I had my ball joints R @ R'd for $20 at a machine shop. Well worth the money. Read the directions on the ball joint installation and pay attention to the preload information. Good Luck, its not too bad of a job.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  9. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    The worst part about the whole job is dealing with the wheel bearing grease. The link given about is to my cheesy right up, but Im no longer using that site so if it fails you can find the same write up here. <a target="_blank" href=http://www.mccords.s5.com/myk5/balljoints.htm>balljoint swap</a>
    Its the popping, rumbling, roaring, twisting, flexing, grinding, so you can wheel anywhere medicine[​IMG]
