Replacing Battery Cables
Discussion in 'The Garage' started by BlahBlah, Feb 18, 2006.
  1. BlahBlah
    BlahBlah Registered Member
    Apr 13, 2005
    10
    Oregon
    I've got a 78 k20 that I just bought a winch for. So I went out and bought a new 140 amp alternator. My question is should I just replace the two wires coming off the battery or should I upgrade the smaller one that goes from the alternator to the starter to? Also whats the difference between a 1 wire and a 3 wire alternator?
  2. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    Here is some interesting reading on alternators.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    As I recall, the highest output alternator offered by the factory in '78 was a whopping 63 amps. :rolleyes: GM sized the charging wire from the alternator to the starter post accordingly. To keep the charging wire from melting when the new 140 amp alternator goes into full charge mode, you definitely need to increase the size of that wire consierably. :eek1: To handle that much current, you need to use at least a 4 gauge wire.
  4. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    a 3 wire has 3 wires: Big red Hot, exciter (usually white), and hot jumper(post to terminal). 1 wire alternator has only the hot wire going straight to the post on the back. If I were you, id run 4 guage straight to the starter from the alternator, and 2 guage from the batterey to the starter. Also a 2 guage ground to the block from batterey.
  5. BlahBlah
    Apr 13, 2005
    10
    Oregon
    Thats pretty much what I was thinking. I even bought some 4 guage for that purpose, but do you think I should leave the old wire and add a new one? Or should I rip out the original, too?
  6. onetonbb74
    Dec 1, 2005
    2,083
    Campbell, CA
    just hook the old wire to the junction block on the firewall
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    hijack:
    anyone know the size of alternator that came in a 84 blazer/jimmy from the factory?
    hijack off
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    If it's got a V-belt, then it's most likely a 63 amp model. :(
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I would remove the old one. The insulation on it has probably seen better days anyway. It gets really brittle down where it passes by the exhaust.
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    thought they had 78 amp models in the 84 some-odd years?
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I just did some quick poking around at www.partsamerica.com and found a 78 amp AND a 108 amp unit listed as available for a diesel powered '84 Suburban. The 108 amp unit is listed for under $100. Not a bad upgrade for the V-belt set! :cool1:
    However, they don't list the 108 amp unit as being available from AC Delco, so perhaps it wasn't a factory option? :confused:
  12. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Not positive about '84, but the optional alternator that's originally was on miy '85 when it rolled out of Flint was the RPO K81 66-amp. Believe it or not, the standard alt on the gasoline models was a 37-amp job! Diesels had the 66 amper as standard equipment.
  13. BlahBlah
    Apr 13, 2005
    10
    Oregon
    Thanks guys! I got it all done. I know I should pull out all the original wire and add new stuff in, but that will give me a project for later.
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Wow I sure hope mines not a 37 amp one. :eek1:
  15. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Theres alot of good info on that site, good post.
