replacing body mounts and bolt sizes?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 70~K5, May 29, 2002.
  1. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    To anyone that has replaced their body mount pads did you write down what size and lengh bolts you used for standard mounts and how many of each. I have a Energy Suspension set coming and would like to have the new hardware so I'm not runniong around for parts in the middle of the swap. /forums/images/icons/smile.gif
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    This is a list from Steve Chin
    Radiator Support: 7/16"-13 x 3.375" carriage bolt
    Body Mount #1: 9/16"-12 x 6" hex head cap screw
    Body Mount #2: 3/8"- 16 x 10" Carriage bolt
    Body Mount #3: 3/8"- 16 x 5.5" Carriage Bolt
    Body Mount #4: 3/8"- 16 x 4.5" Carriage bolt
    Body Mount #5: 3/8"- 16 x 5.5" Carriage bolt
    I used all those sizes when I put on my Energy Suspension kit.
  3. swamp donkey
    swamp donkey 1/2 ton status
    Apr 29, 2002
    186
    Thousand Oaks, CA
    I took that list to my local hardware store and they did not have some of it in grade 8, but other than that it worked great.
    I suggest you lossen all bolts (or even remove all nuts, but leave bolts in). Then replace one bolt at a time. I took all bolts out of one side, jacked up the truck, put in the new mounts, lowered the truck... and then had a devil of a time getting the bolt to drop down through everything. If you do one bolt at a time the body won't be inclined to shift... Including 1000 trips to my local hardware store (some of the included washers did not fit because... well long story). Anyway, with airtools and a floor jack I did it in half a day.
    Good luck.
  4. NuBombs72K5
    NuBombs72K5 1/2 ton status
    Jan 21, 2001
    145
    Georgia
    Let us know how it goes for you. This is the next thing I've got to do. Thanks Triaged for reposting Steve Chin's list.
  5. tp85
    tp85 1/2 ton status Premium Member
    Mar 14, 2002
    130
    Maryland
    yeah, please let us know how it goes. when do you plan to do the job? i plan to do the same in a few weeks. i just ordered the std complete body mount kit from gmcpaul. he was out of stock, so i'm not sure when i will see the parts.
