Replacing cigarette lighter receptacle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, May 3, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    How hard is it to replace the cigarette lighter? What holds it in? How are the wired attached to it? Mines dead and I need somewhere to plug my portable CB in. Thanks
  2. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    Are you sure it's the recepticle? Mine is dead also but the wire has no power. The fuse is fine. The wire connects with a simple female connector. Get a test light and check for power before getting a new recepticle.
  3. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Probably easier to take a peek @ replacements @ Wal-Mart/K-Mart/Parts store and see how they are mounted. Normally an outside shell that threads onto the dash piece from the back (front has bezel & connections, the outter shell, and then the element/pop-out piece). Depending on the ground (via dash or seperate wire), they plug into back. Make sure and check your fuse as well! I've added them all over my sub for convienence!
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The cig lighter in my Blazer is bad also. I'm consittering getting a 3-way power port. ( looks like 3 cig lighter receptacle ) I'll probley mount it under the dash.
  5. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Well, I got it to work and now I can't find my handheld CB.
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    for future reference, the little metal sleeve is threaded and has another peice that holds it in. I replaced mine last year with a generic "replacement" one and it worked great.. kind of a pita and not a very clear explanation but if you take a look you'll see what I mean.
    mike
