Replacing Fan ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jackson 88K5, Dec 13, 2000.
  1. Jackson 88K5
    Jackson 88K5 1/2 ton status
    Oct 27, 2000
    104
    Topsham, Maine, USA
    Should I go with the Flex fan for my stock 350 or use the factory clutch fan?
    If it breaks, upgade it.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Use the factory clutch fan. It will cool the engine better and create less drag on the engine when the clutch releases.
    http://ThunderTruck.ColoradoK5.com
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Yeah, like Harry said, the flexfan is a real power thief. If your truck is stock, and you don't do too much towing, your clutch is probably hardly ever enngaged anyways. The only time my clutch kicks in is when I'm towing in the mountains in hot weather- other than that, I never hear it.
  4. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Got a bunch of stiches in my hand years ago from one of those "flex" fans. Never cared for them. Replace it with what you had.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    fu#*it just go with an electric lol
    s.smith 77blazer lookin 4 mud
  6. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    I'd go with an electric fan, too. They will not drink your engine's power as much. I've got electric fans in 2 of my cars(FWD - arrrggghhh) and I'm about to install electric fans in my Blazer and Firebird, once I get the money.
    [​IMG]http://www.ncclassics.com
  7. Jackson 88K5
    Oct 27, 2000
    104
    Topsham, Maine, USA
    Might hvae to check into that&gt;[​IMG].
  8. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    There's a couple reasons I haven't upgraded to an electric fan.
    First is the air flow. An electric fan can't pull as much air as an mechanical fan. This is critical if you're running a big block like I am. Even with a pusher and puller fans, I've heard the mechanical fans will still out-perform the electrics.
    Second is the current draw. Yes, the electric fan might help a little on hp but what about when you're winching? At a dead stop, both winch and electric fan will be drawing from the battery/alternator which isn't a good thing.
    Third is cost. With a multiple electric fan setup, plus the thermal switch, that seems to add up to some cash which could be spent better on something else.
    I'm actually thinking about one of those new plastic fans that replace your steel fan. Suppose to be less weight and better for your water pump but I'm not sure if they can cool as much as a steel/alum fan.
    Shawn
    87 K5
    few mods[​IMG]
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    shawn they might not flow as much air as a steel or aluminum fan but you can turn it off and on with the flip of a switch makes it very nice 4 water crossings and you could turn it off while using your winch. no need 4 the thermal switch just use a toggle switch. there are prose and cons to both just personal preference
  10. Shawn
    1,753
    5
    5280'
    I realize you can use a toggle for the electric fan but it's another thing you would have to worry about when winching. Knowing myself, I'd forget to turn the fans back on just like my electric fuel pump since it's on a switch. Talk about embarrassing times when you pull out a parking lot and the thing dies on you from no fuel![​IMG] Like you said though, there's pro's and cons to both.
    Shawn
    87 K5
    few mods[​IMG]
