replacing front coils?
Discussion in '1983-2005 S-Series models' started by bryguy00b, Nov 7, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    how hard is it? i have to do it one my s-10..the driver side spring is broke..one of the coils on the bottom are broke and you can see it..thats why it leans a little to the side..
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I've heard that you can do it without disconnecting the lower ball-joint but I have never done it that way. To do it this way you would have to remove the inner piviot bolts for the lower control arms and lower it with a floor jack. The way I have done it is to undo the lower ball-joint and drop that end with a floor jack...but you will mess up the dust boot with a pickle fork and most will not come off any other way. That means you will also need a new ball-joint.
    Either way you will most likely need a INTERNAL spring compressor which you can rent for free (just a deposit that you get back) from AutoZone and maybe some other parts stores.
    I would not recomend just doing one. It isn't that hard of a job but some of the stuff can be tough to go back together.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thanx ill keep this in mind..i might just let it go for the winter...really cold out now to do to much..i just gatat get the brakes done and get a new windshield in it..then put it on the road..
