replacing front door window motor
Discussion in 'The Garage' started by steve_kibbe, Jan 26, 2006.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    The window is down, won't come up. Is there a trick to get it out of the way? I can bairly fit my arm throught the square hole, just to be able to touch the top of the old motor.
    Any help will be greatly appreciated.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    tap the motor with a "hammer" might get it working again.
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Front/sides or rear?
    The rear cable can be easily disconnected and run with a dril motor.
  4. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Sorry, front ds window.
  5. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Tried, but no luck. Thanks though, didn't even think of that:wink1:
  6. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    take the plug off and run 12 volts directly to the motor. if that doesnt do it nothing will.
  7. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Got it all taken care of today. Talked to clarkjw24 last night and he walked me right through it. Thanks alot John, you rock:saweet: :saweet:
    1) remove door panel.(duh)
    2) remove two bolts and two nuts the hold the track system to the door.
    3) get the window off the track rollers and either remove it or support it up out of the way.
    4) take the brace and handle rod off. Take track system out of door.
    5) replace motor and reassemble.
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Nice!
    Don't forget to clean the tracks (rubber and felt piece that the window slides in AND the roller tracks on the regulator). I then use the white spray on grease on all tracks.
