replacing front inner seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigdaddy89, Mar 21, 2001.
  1. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    I have to replace the front inner seal on my 10 bolt front end. Does anybody know of any tricks to get this in? I saw a mechanic use a homemade tool once before that looked like a huge socket with a arm welded on it so he could pound it in with a hammer. I don't have on of these and don't know of any special tools. Give me some idea's here guys, I want to go break something this weekend, so I need to fix it tomorrow.
    GOT ROCKS?
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    yank on it with some pump pliers you can also use them to grab and pry
    Doug Krebs
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: replacing front inner seal *DELETED*
    Post deleted by BadDog
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I think he means break stuff on his truck [​IMG] I used a BIG socket and a BFH to pound it in. It took a couple of tries to get it in straight so take your time
    Murphy's Laws on Life :
    "It is a mistake to allow any mechanical object to realize you are in a hurry."
  5. dyeager535
    26,980
    I apologize...I can tell Grim was singling me out, as well he should. I didn't clearly understand what "front inner seal" was...so I've edited this and taken out the info on how to replace the pinion seal : )<P ID="edit"><FONT SIZE=-1>Edited by dyeager535 on 03/22/01 04:39 PM (server time).</FONT></P>
  6. You could always drive over it
    '84 K5
    Chevy in my blood.
  7. Grim-Reaper
    7,385
    Atlanta
    Well other than the hub wrench no special tools needed to replace the INNER AXLE SEALS. and you don't need to remove the yoke. You however do need to pull both axle shafts. When I replaced mine I used a big socket and turned my framing hammer sideways and tapped it in. A bud has about 30ft of extensions and he just hooks them all together and taps it through the tubes when he puts them in.
    Might do a search. This topic comes up often and there have been several detailed posts in the past.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  8. bigdaddy89
    May 18, 2000
    422
    Phx, Az
    Thanks for all the ideas.
    GOT ROCKS?
