Replacing Front seal np 241 Q's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lowlevell, May 6, 2001.
  1. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    Replacing Front seal np 241 Q\'s
    My front seal on my X-fer is shot and i need to replace it. Is this the job as the rear? Or does this this have a crush sleeve?
    One From None
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Re: Replacing Front seal np 241 Q\'s
    i need to find out about this too. either my 700r4 or 241 (or both) is bad because my t-case keeps filling up with atf from the tranny.....
    AIRBORNE!!
  3. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    oops, i just re-read your post and you asre talking about the front OUTPUT seal.....the one i need a little advice on is the tranny to t-case seal
    AIRBORNE!!
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Theres no crush sleeve. Its just like doing the one in there rear other than the fact that its just a bit more of a pain in the ass to get the old one out.
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  5. lowlevell
    Jun 27, 2000
    343
    Central Ohio, USA
    Damn dude, you have problems. My x-fer is just leaking out of the front shaft. Does that yoke just come out like the rear? I seem to remember seeing a big friggn nut holding it on. Kinda like an axles' yoke. Thanks guys
    One From None
  6. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    Aiight, I did this a couple of weeks ago, and Brandon was there to witness it. It wasn't hard, but took a while. Kinda odd angles to pry that seal out. Yes, there is a big nut that you have to loosen. Get a bigass breaker bar and I think 1 1/8 socket. I had to use my legs to break it free. after that pry that seal up. I used a screwdriver and a hammer. Getting the old stuff out is hard, putting it all back in is easy. Have fun.
    BuSH
    -JoSH
    crazeebush@aol.com
    <A target="_blank" HREF=http://josh.coloradok5.com>http://josh.coloradok5.com</A>
  7. lowlevell
    Jun 27, 2000
    343
    Central Ohio, USA
    Thanks, I did the rear one about a month ago, now its time to do the front. Looks like the warranty ran out on my X-fer case seals this month:)
    One From None
  8. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    A 241 is suppose to be full of ATF.....
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Hey yield, yeah the 241 case is filled with ATF. If your tranny output shaft seal is leaking it will allow the tranny fluid level to drop and increase your t-case level, to the point where it will start coming out of your slip yoke relief whole.
  10. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    yeah, but not so full that when i take the fill nut off it runs out, and my trans is always low!! making me mad!!!
    AIRBORNE!!
  11. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    ftn96, the post above was not for you!!! kinda sounded like a smart a$$ remark, didnt see your post until after made the other reply!! i am a jack arse....
    yeah, i need tot fix that seal, i never realized the two made a connection so that the fluid from the trans can reach the t-case..there for a while, i was thinking i was over filling the t-case, but there is really no way!!
    AIRBORNE!!
