replacing fusible links with fuses
Discussion in 'The Garage' started by ryan22re, Nov 8, 2005.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    was thinking about replacing the the fusible links on my truck (87 k5) with fuses when i do the battery relocation/cable upgrades. ive never really seen a wiring diagram or really even paid that much attention to the wires on my truck. im assuming that theres a couple coming from the alternator and a couple coming from the starter. any ideas as to what size fuses to use?
    ryan
  2. spydermonkey454
    spydermonkey454 Registered Member
    Sep 30, 2005
    33
    lexington sc
    what color are the fuse links
    they are rated by color
  3. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    i got rid of all my fuseable links and just run a big maxi fuse...
  4. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    I burned my fusible link when my 150amp alternator bit the big one. I replaced it with a 60amp Maxi-fuse and haven't had any trouble.
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    i dont know. its still dark outside.
    what i really need, is what i saw on rootbreaker's truck, 96-98 H body fuse/relay center.
    ryan
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    This isn't a great idea. Each wire that is protected by a fusible link can only carry a certain amount of current, perhaps 30 amps max. Hooking multiple circuits into a mongo single fuse doesn't provide protection for the individual wires. A short in one of the wires could draw more current than the wire can handle, but less current than it takes to blow the fuse. That's a recipe for an electrical fire. :eek1:
    The correct way to wire it would be to have smaller fuses replace each of the individual fusible links.
