replacing hood on 71 tips
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by bp71k5, Apr 26, 2006.
  1. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    Hi,
    I was dumb enough to detach the hood on the truck to try and make it latch better and quit scratching the paint below the windshield. Now, the thing is way out of alignment. Anyone have any tips for getting this back straight? The back end seems to ride too high when it's closed, but you can press down on it and it'll go down to where it's supposed to be.
    Thanks,
    Brian
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ya mine kinda does that too.
    I tried losening the bolts to were they were still snug..then closed the hood and with my fist pound on the corners then slowly open it up enough to get to the bolts and tighten...close and repeat...Got mine fairly close this way...
    Good Luck
    Burt
  3. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    you have to loosen up the bolts that hold the hinge assemblies to the fenders the rear-most two ones and pivot the back end of the hinges downwards a bit
    this will make the back of the hood shut down further
    been through this a billion times 67-72 owned a million and removed and replaced billions of these hoods, by myself, i do all my stuff alone
    its a balancing act but not that difficult
    good luck
  4. bp71k5
    Mar 31, 2006
    6,235
    284
    Thanks for all the tips, I'll try 'em all.
  5. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Billions??? :haha:
    Man, how do you find the time to even visit CK5????
    :usaflag:
  6. bp71k5
    Mar 31, 2006
    6,235
    284
    I think I got it about as good as it'll get. Loosening the two rear screws seemed to do it. I also found that I wasn't able to get it down all the way until I fixed the gap between the hood and the body so it was a consistant 1/8 - 1/4 inch all the way around. Once I did that, it dropped down all the way. Maybe that'll help someone else.
    Thanks!
  7. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    make sure your hood hinges are well lubed at the pivot points. when they are dry your hinges can bend and the hood might never sit right.
  8. bp71k5
    Mar 31, 2006
    6,235
    284
    Yea, one of the hinges looks like the pins are really loose which makes it sloppier than the other one. Probably need to get some new hinges. Anyone ever used the repro ones? Are they any good?
