Replacing Ignition control module
Discussion in 'The Garage' started by riggz, May 10, 2005.
  1. riggz
    riggz Registered Member
    Feb 9, 2005
    85
    Roswell, GA
    So after all this time of trying to figure out why my truck will start and run fine for a minute or so, then start running horribly rough, i just now get a new SES code.
    42 = Ignition Control short/open/component failure.
    A replacement module is only $30 so I'll give it a shot. My question is... Where is it located and how do I replace it?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Its easy. It is located underneith your distributor cap. Disconnect the battery. Unscrew the 2 screws that hold the cap on. Pull the cap and pull the rotor. Unscrew the 2 screws that hold the module in place and pop off the 2 connectors. Clean the distributor area where the old module sat.
    LUBE THE NEW MODULE. Use the packet of dielectric grease in the box with the module on the bottom of the module. Put is on and spread it around the metal surface.
    Reconnect the connectors to the new module and install new module. Replace the rotor and then cap. Reconnect the battery and try and start the motor. If is won't start then you have other problems.
    Harley
  3. riggz
    Feb 9, 2005
    85
    Roswell, GA
    ok great! thanks for the fast reply. ill try this out tomorrow.
  4. slacker
    slacker Newbie
    May 11, 2005
    h-town
    hey let me know if this works, i got a code 42 also on my 89 suburban 350 tbi. my motor runs good till it warms up then the check engine light comes on, the idle drops and for some reason the exhaust gets real loud. still runs ok though...weird
    i kinda like the louder exhaust now...gonna redo it after i get this fixed and probably put a flowmaster on it.
  5. dyeager535
    26,976
    This might save you some money.
    Code 42 diagnostics
    That's the F-body carline, but TBI, so should be identical in regards to code 42.
