Replacing lifters, but not cam?
Discussion in 'The Garage' started by AussieK5, Aug 16, 2006.
  1. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Ive always treated my lifters and cams as matched sets on any engine I've built or played with, as you should. Unfortunately doing this leaves me with no experience as to how long it takes a set of fresh lifters to munch a old camshaft. Something I'd like to know.
    I ask this question with regards to a cheap V8 parts chaser I'm using while the K5 gets restored,.......
    Dont worry I wouldnt do this with any engine I want to hang on to or depend on for DD or expedition duties.
    Has anyone got any experiences they can share? I'm looking for input from guys who build their own engines and have first hand observations.
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    If its a roller cam, it makes no difference, which is why no break in is required for roller cams. If its a flat tappet, then you need a new cam/lifter set. Each lifter wears according to the lobe its on.
    You might very well be fine using new lifters on a old cam, but i wouldnt do it the onther way around. Its not something I would do, but you could try it.
  3. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I have a 69 buick Riviera with a 430 engine. It had been parked for several years and at least two lifters colapsed. I pulled out the old threw in some new(all 16) and its run fine for the last 7 years. I think i may have run a break in on it but can't remember. My father has done the same on his crysler 383 with no ill effects.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You can use new lifters on an old cam but not used lifters on a new cam or different cam because it will wear out the cam lobes.
  5. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Thats what I wanted to hear :waytogo:
    Out of curiousity I'm going to record the lift on a couple of lobes and check them after a 1000 miles or so of running.
    Thanks guys
  6. dyeager535
    26,980
    Add me as another person thats successfully done the new lifters/old cam deal. :)
  7. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    x2 :wink1:
  8. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Liquor then Beer, Never fear... no wait... new lifters old cam, never fear... that's it.
  9. diesel4me
    Jul 24, 2003
    17,569
    943
    Massachussetts
    Me 2!
    I've put new lifters in many engines without changing the cam,did it to my 69 GTO,a 250 Chevy six,and many other cars in the shop with no ill effects..I'd never put OLD lifters on a new cam though,thats a sure fire way to destroy both..sometimes just swapping in new lifters will "eat" a cam lobe,but chances are if it does,it was already worn down beyond the hardened lobe surface..
    It's always best to replace BOTH,but in my cases,most of the engines and cars were nothing special,and didn't have to be "perfect",I just wanted all the valves to open and close again!..and not drive me nuts listening to them clattering..:crazy:
  10. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    It ought to work all right.
    However, if I had the engine pulled and bolted to a stand already, and was going to be removing the intake manifold and valve covers in order to change the lifters, I couldn't live with myself if I didn't pull the water pump, front cover, and timing chain, then just put in a new camshaft with the new lifters. Nothing radical for a humble parts runner, just something like an RV-type cam.
  11. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Me to, but i would NEVER pad.
  12. Slapperbar
    Nov 29, 2005
    2,747
    3
