Replacing lug bolts-whose got the tricks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LAZYMON, Oct 3, 2000.
  1. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    I need to replace 2 broken stud bolts from the same wheel. Front disk brake. What's the best way to go about this? I've done it on rear drums on a car but not a 4X4.
    73 Topless Blazer
  2. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    You'll have too remove the the hub and spindle.Then use a punch and BFH.Repack the bearings while your there.And if two broke then there all too old.I would replace all 6 or 8 depending how many you got.Almost forgot on the back side of the rotor theres a seal they cost a buck or two.I would replace that too.
  3. LAZYMON
    Jul 26, 2000
    235
    Lake Tahoe
    Do I need a special tool to get the rotor and hub off of the spindle? Some kind of hub socket or puller?
    73 Topless Blazer
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Whack it with a hammer........ Whack it, whack it.......
    Whack it hard....... Whack it...... Whack it with a great big hammer!!!!!!!!!...........
    WHACK IT..... WHACK IT...... WHACK IT.........
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You need a hub socket to get the hub nut off. They cost about $20, but it's a needed tool, so get it. (Sam goes if you get a 14bff rear axle,k it has a special hub nut socket.)
    If I remember correctly, I replace the wheel studs on my 1/2 front axle (before I swapped it out) by hitting them out without removing the hub/rotor assembly. Carevully extract them, then carefully put in new ones. Put on your wheel, use a big breaker bar (or impact wrench for those with the bigger wallets) to seat the studs. It worked fine for me.
    When I going through my 3/4 front, I pulled the rotors to do it because I replaced the rotors anyways. Your call.
    It's pretty easy either way.
    -- Mike
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Hey TX Mudder,
    Where can you get that Hub Socket? Would a place like Sears carry them? Or would I have to go to Advanced auto or something. I'm trying to remove the drums on my 14bolt FF that I have in the garage and couldn't figure out how till I read your post. Thanks
    Boss
    http://www.boss.coloradok5.com
  7. LAZYMON
    Jul 26, 2000
    235
    Lake Tahoe
    TX Mudder gets the prize
    Well there is no prize, but there is no need to pull the rotor. Out the back with minor modification. There is a notch that lines up behind each bolt, but there is also some kind of shield blocking extraction, it's thin steel so I drilled out a bit off the edge untill the bold head cleared. Then I WHACKED IT out. Thanks EMMETT. The new ones slid right in. Hold them with something tight so it doesn't drop down inside, that would be a bummer, hard to get. I took a old lug nut and two washers and torqued it with a torque wrench untill they were seated. I wrote all that in case some else wants to know. Anyway it's all back together and it cost me $4.50 and some time. I learned some stuff about my hub, brakes and suspension so I guess we win another one.
    Next Project
    Thanks All
    Later
    73 Topless Blazer
  8. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Boss,
    I got the socket for the front at NAPA. I have also seen them at Pep Boys, Kragen, ect.
    blazen91
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    My local Autozone had the hub socket for the front axle.
    I had to go to a mom and pop auto store to get the 14 bolt's hub socket. All the big chains just didn;t carry it, I have no idea why. I was getting pretty pissed till I found the ONE the small store had.
    To whoever said that the hub was the only thing stopping them from getting the drum off - I had the same problem, I didn't know it was unlike semi-floaters and neeed the hub nut removed. I think it was Squash who clued me in. I sure felt like an idiot LOL
    -- Mike
