Replacing Manual Hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mreetz, Oct 2, 2002.
  1. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Did a search, found nothing. Need some help replacing some MM manual hubs on my '84. I did mine when I bought but have since lost the info. I can get the outside off, the spring, inner gear. I cannot get the middle of it out. I removed the retainer ring and that's as far as I can get.
    HELP
    Marty---
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    There is a retaining ring that snaps into the actual wheel hub. It holds the rest of the lockout in the hub. Its a pita to get out. It just takes time and patience. Use a small screwdriver and pick tool.
    Hope it helps,
    John
  3. Mreetz
    Jun 26, 2001
    1,282
    It looked like there was somthing back there......thanks!! /forums/images/graemlins/thumb.gif
  4. Mreetz
    Jun 26, 2001
    1,282
    Holy Cr@p, these things are impossible to get at!!!
  5. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    someone suggested using a dental pick.I tried it and it worked great but,I've found if you try too hard the pick will bend. You can get one at any drug store. /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/truck.gif
  6. NetBlazer
    NetBlazer Registered Member
    Apr 23, 2001
    90
    Littleton, CO
    Yeah, those snap rings are a big PITA to get out. I have the same hubs on my 88 and have been popping them in and out a lot lately in my axle swap and rebuild, (and subsequent teardown for balljoints after I got it all in the truck /forums/images/graemlins/angryfire.gif.) What I found works well is to get a couple of small screwdrivers, I like the little pocket ones that us PC guys seem to have lying around everywhere, and jam one in about an inch or two from one end of the ring and pry it in towards the hub body, then take another small screwdriver and stick it under the end of the ring and pry out. Then just work the ring out the rest of the way around. It also helps to get the hub body out if you screw one or two the the cover screws back into the hub body and use them as handles to remove the hub body.
    Hope this helps.
    Sean
