Replacing mechanical fuel pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beachinblazer, May 6, 2002.
  1. beachinblazer
    beachinblazer Registered Member
    Apr 15, 2002
    20
    I am replacing my mechanical fuel pump and after removing the old one, the push rod that operates the pump lever slid down to block the opening. What is the trick to getting the pump push rod back into place so you can slide the pump lever in the slot and bolt it on?
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Get a gob of grease on the end of thr rod and slide it in......the grease will keep it from sliding out.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    You can also use a hacksaw blade to hold it up while you slide it in.
  4. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    A hacksaw blade works pretty well for holding it up in place. Also, for future reference, look at the front of the block on the passenger side. There are two bolt holes, one above the other. The top one should have a short 3/8 bolt in it. Before removing the old pump, pull this short bolt and thread in a longer one until it bottoms out. Now when you take the pump off this bolt will hold the pushrod up. Just be sure to remove the long bolt and replace it with the short one before you fire it up.
    eric
  5. MudbogAD
    Jun 29, 2001
    672
    That's cool! Never knew that./forums/images/icons/smile.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    some SBC dont oil the fuel pump enough, like mine.
    the instructions with my last Carter pump say to fill the pump with grease in the lever area
