Replacing MOTOR MOUNTS
Discussion in 'The Garage' started by wadinator, Nov 18, 2003.
  1. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    Hey all....
    I gotta replace the motor mounts on my 87 1/2tn Suburban with a 350tbi. I've never done this before, so I'm looking for pointers.
    I'll be lifting the motor using a floor jack on the harmonic balancer. My bro-in-law said to wedge a block between the oil pan and the frame in case the jack lets go. After the motor is lifted and braced, it should be pretty easy.
    Am I missing anything? Thanks! /forums/images/graemlins/thumb.gif
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Wade,
    I have done it this way essentially. Just be careful and gently take the weight off of the mounts as you remove the engine mount bolts. I would put some wood between the pan and jack rather than use the harmonic balancer. You can do it with out damaging the pan. I am leery of putting the weight of the engine on the harmonic balancer. I'm sure there are other opinions though.
  3. wadinator
    Dec 18, 2001
    233
    NW Iowa
    I was just told the same thing elsewhere.
    Seriously? The oil pan will be able to take that much weight? I'll gladly go that route, cuz I'm afraid of bending the crankshaft or something by jacking on the harmonic balancer.
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used a floor jack and a 4x4 to the oil pan when I did my mounts. It seemed to work fine.
  5. wadinator
    Dec 18, 2001
    233
    NW Iowa
    Alrighty. Maybe this is the way to do it then. Did you have some sort of backup, to prevent your hands from getting crushed in case the jack lets go?
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I stuffed a 2x4 up in there somewhere at the same time. Maybe between the crossmember and the pan. I cant remember exactly where, but somewhere.
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Just make sure the board you use covers the hole bottom of the pan. If you only use a 2x4 it will bend the pan "from experience"
  8. wadinator
    Dec 18, 2001
    233
    NW Iowa
    Can (and should) a guy try to loosen the bolts holding the mount to the frame before jacking and backing out the big bolts? That way your not tugging and wiggling the whole truck trying to loosen those bolts while the motor is being held up by the jack.
    Just a thought from a guy who's never done this before....
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    just dont put weight under harmonic dampner, you risk damaging the thing because you could cause outer ring of dampner to move, which would ruin it, only thing holding it to hub of the dampner is rubber
    once engine is lifted up you will be able to get engine mount removed /forums/images/graemlins/laugh.gif
    wont be too bad, just take your time and make sure that engine will not come down when you dont want it to, i am very cautious when i have to replace or swap or reposition mounts or mounting brackets with engine in the engine bay, one slip and you could lose one or more fingers. i guess i have survived through jobs like that by being overly cautious, or maybe just by luck, dunno,.
    good luck
  10. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    Like other have said use a 4"x4" board wider than the oil pan and raise it enough to get the mounts out just be careful not to raise it to high, as could damage the distributor cap.
    Jayson
  11. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I have seen People do it with the balancer, and I just shake my head. You are ablying force on
    1 the balancer
    2 the crank it was not designed to be a lifting point
    3 the bearings not designed to support an engine.
    best way to do it is with a cherry picker.
    with out a cherry picker you can do it with the floor jack/oil pan deal but if your pan is rusty beond surface rust you may collapse the pan. If this is your situation I have done them by using a 2x4 between under the fuel pump ON THE BLOCK not the pump and the on the ground , jacking up the tuck and letting it down slow with the motor mount bolts out. For saftey sake I would reomend getting a 2x4 that will fit from the cowl to the core support settign it across and chaining the engine to it after lifting it incase your hands are in there and the motor drops.
    good luck they are cake really
  12. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Ditto on the cherry picker. It's worth the rental fee if you can get one nearby. I just bought one and I've already recouped my money many times over.
  13. wadinator
    Dec 18, 2001
    233
    NW Iowa
    Try not to laugh here... by core support, do you mean the radiator support? And what's the cowl?
  14. 99firehawk
    Dec 15, 2002
    491
    The core support is the radiator supprt yes, Just make sure its on the support and not the radiator, ( I havent seen under the hood of a k5 with a factory radaitor init in a long time so the radiator may be to high to do this, you will have to check) the cowl is the area bewteen the windsheild and the hood the wipers protrude from the cowl.
    DISCLAIMER:
    Now under stand that if the block did fall you MAY slighty dent the cowl or core support, In my eyes I would rather have 2 hands to hammer either back out IF it did fall, then have to look at a strait core support and cowl in a truck I cant drive Becuase I have no hands.
  15. wadinator
    Dec 18, 2001
    233
    NW Iowa
    Thanks to everyone who shared pointers with me!
    The motor mount replacement went off (almost) without a hitch. I somehow pulled one of the plug wires loose from the distributor cap.
    Thanks! You guys are great!
