Replacing Power Steering Reservoir
Discussion in 'The Garage' started by scubahard, Feb 28, 2005.
  1. scubahard
    scubahard Registered Member
    Nov 3, 2004
    47
    California
    My Power Steering pump is leaking and sounding like it is on it's last leg so I am going to need to replace it. I was looking at AGR PS Pumps as a replacement, but none of them come with a new Reservoir (stock location). Does anyone know of a shop/online company that sells just the reservoir or Reservoir/AGR Pump? AGR does not seem to have one, is this true? Thanks.
    1981 K1500
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    The resevoirs come off easily. Just a big o-ring, usally supplied with the new pump, and pop your old resevoir onto your new pump...
  3. scubahard
    Nov 3, 2004
    47
    California
    That does not sound bad at all. It is hard to tell where the leak is coming from, but it looks like it might be coming from the Seams on the reservoir. I won't be able to really tell until I remove the pump. Although,....i did just replace the belts so maybe as i was tighening the belts it broke the seal on the shaft.
    I was hoping to get all the parts that I might need before I take it all apart. I do no think the Reservoir will be that expensive, if i can find it.
  4. dyeager535
    26,979
    How bad does it sound? As an option to replacement, try using some of that power steering fluid with stop leak. That stuff can work wonders.
    All the power steering pumps make SOME noise I think (probbaly not brand new, with age) so if it's just once in awhile, or under hard load, I wouldn't worry too much about it. Mine sticks when it's cold, (also common) one of these days I might get around to doing something about that. :)
  5. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Not to hijack but this might end up useful.....What do yuo guys think about doin that radiator hose extension on the reservoir? Ive heard good stuff about that.
