Replacing Rear Main Seal on the 1991
Discussion in 'The Garage' started by Fubeca, Nov 6, 2003.
  1. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I need to replace the rear main seal on my blazer. It is a '91 so I think it has the one-piece seal. I haven't pulled the flexplate off yet but the book says I need to drop the oil pan. Is it necessary to drop oil pan?
    Are there any tricks I should know about before doing this?
    One other thing, anyone know of a good place to get motor mounts that are tough but still retain the tabs that the inspection cover struts mount to?
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    The rear main seal is a one piece style so no need to pull the pan.
    As for the motor mounts the support rods that go to the tranny inspection cover bolt to brackets that are sandwiched between the block and the upper motor mount "bell".
  3. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    No need to drop the pan as stated above. Just 'pop' the old seal out. Be careful not to score or scratch up the edges where the seal sit though. Before you install the new seal...get some fresh new motor oil and run with your finger, run it around the edge of the seal to help it slide in easier/forums/images/graemlins/thumb.gif Once you are installing the seal...you will feel it 'bottom out' so you know its all the way in.
    I believe the make a special install tool, so you can get it lined up right and pressed in correct with the motor still in the truck.
    I did mine before I put the engine back in...so not sure how much of a PIA it is with it still in the truck.
    Good luck!/forums/images/graemlins/thumb.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    just make sure to take your time and install it straight carefully /forums/images/graemlins/laugh.gif
  5. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    If I remove the seal retainer, then do I need to drop the pan?
