Replacing rear sidewindow on my suburban - need help
Discussion in 'The Garage' started by ankarback, Nov 9, 2005.
  1. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    What is the easiest way to replace the rear left sidewindow in a suburban? Seems like it's very easy to crack the new one when you press it into place.
  2. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Yes, they are easy to crack. Just be careful, and push with your whole hand to spread the pressure. This may sound dumb but you are putting the gasket in first and then putting the window in it right?
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Install the gasket in the frame first, set the window into the lower portion of the gasket, and work the rubber around the rest of the frame. i found it easier to lube it with something like soap and water mixture to help the window slide into the rubber, use some tools if you have them, like plastic items to work the rubber around.
    then installing the little rubber piece in the middle is even more fun :doah:
  4. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    Sounds like it's going to be fun :doah: Maybe a stupid question but do I need to glue the gasket to the frame to prevent it from leaking.
  5. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Negative, you don't need to seal it. However you can if you'd like. I'm a self proclaimed expert on this now :D here is how I do it.
    Tools: dish soap is your new friend! Use it liberally. Get yourself something firm, preferably plastic, or carefully use a butter knife. A rag to clean the soap off your hands (sounds stupid but wait until you're struggling with the freakin knife and gasket with slippery hands!), A buddy.
    Like already said place the gasket onto the body first. Get a buddy to help you put the glass in place and hold it while you work the glass into the seal. Start in a corner any will do but if your truck is lifted a bottom corner makes sense and use lots of soap. Using firm pressure push the glass into place. It should be easy until you get to the last corner, at this point you will really need to use whatever tool you chose to 'lift' the lip of the gasket up and over the glass while applying pressure.
    Next is the solid rubber bead. This is slow and tedious but not difficult. Start at the bottom edge, GM started about three or four inches from the rear corner. The bead has two lips on it. Place the inner lip into place in the gasket, lube the gasket and the bead with the soap, and press the second lip into the gasket with the knife, slightly stretching the bead as you go. At the end you will have extra bead, just cut and replace the metal cover to hide the junction. Wash off all the soap, and you're done. I've done this a bunch of times this summer and didn't break a single window. I'm sure you'll be fine.
  6. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    Thanks for the help. I've bought the window used with the sealing allready attached to it so I have to figure out a way to remove it first then.
    I'll post on here again if I run into trouble. I'm probably not doing this until this weekend.
  7. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    just like the windsheild??
    Sounds much the same way the windsheild goes in??--(never did a side window on a "burb yet)..I thought they would go in like the rear window on a pickup,and you'd use speaker wire or rope to suck the gasket into the metal cutout of the body..hmmm!
    If I had a Suburban with a broken side window,I think I'd smash the other one too,and sheet metal over the openings and fill it smooth!.."Panel" suburbans look awesome,and GM never made any after 1972 that I'm aware of.. :bow: :crazy:
  8. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Yep, exactly the same as the windshield. And no need to use wire!
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    it actually makes it much easier to use rope or wire. personally, i have used 1/4" nylon rope with great success.
  10. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    VistaBurb
    Guys, Fireplug is way out in front on this one. I also just "popped-in" the glass, and it does sort-of fall-in at the last. Took a look at the bead up next to the window at about 2 PM on Sunday and said, I'll wait until Sat. right after sunrise so's I'll have the whooole weekend to fondle that bitch.
    Thanks Fireplug :D
  11. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Wicked cool Idea :bow: ...... If I ever break a side window, I may scarifice a bit of visibility in favor of making it look freakin awsome :saweet: Panel trucks just make me feel warm and fuzzy in side :D
