Replacing Speedo Cable ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Apr 8, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK It finally died... The Speedo used to jump around... now it doesnt move at all... it died right??? Just making sure...
    How hard is it to replace??? Is there one cable or two???
    Anyone know the cost of the cable? I have a 78 Blazer with a 350/350/203...
    Oh and where is the speedo gear located?
    Um... yes officer I know it's too big...
  2. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    one cable and under $30.00 at checker
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Its cake to replace it. Im not sure about your '78 but on my '82 there are two cables. One runs from the back of the gauge to the cruise unit on the wheel well and then from that comes the other cable which leads to the transfer case. To remove the cables, simply turn them off by hand. To test the cables just undo both ends and turn one end with your fingers and check the other end for movement. My guess is that your cable is probably broken. If you dont have cruise then you'll probably have to take out the whole gauge cluster and pull the cable off of the back (only one cable, goes from the gage to the t-case. The speedo gear is located in your trasnfer case, easy stuff to fix but I think its your cable.
  4. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    $12 bucks napa not too ahrd the hardest part is hooking it up insdie the cab you might be able to get away with jsut use the iner calbe the houseing in withc its really easy and cheaper this is if there is not crusie its a jsut one cable
    Bandit
    (Your right i dont understand the jeep thing)<P ID="edit"><FONT SIZE=-1>Edited by bandit on 04/08/01 10:12 PM (server time).</FONT></P>
  5. reddog64
    Nov 9, 2000
    3,325
    I have cruise but it broke... So can i bypass teh cruise setup and just get the standard long cable???
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes you can just get the longer cable
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
