replacing speedometer cable?
Discussion in '1982-Present GM Diesel' started by woods, Mar 4, 2004.
  1. woods
    woods Registered Member
    Feb 18, 2003
    73
    any tips on changing this out mines been broke for about 2 weeks finally got the parts to change it, currently working midshift so hoping to make this go fast as possible so I can get back to sleep
    Woods
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Not really much to it.
    Disconnect the bottom side off the Tcase.
    Lay down on the floor under the dash and reach in with your hand following the cable to where it connects to the speedo, the is a tab that locks it in, with one finger lift that tab and slip the cable out.
    Pull the old cable out, and then route the new one in, reach in again and put the speedo end at the speedo and push till you hear a click.
    Go down under, and spin the internal piece to make sure it slipped in without bind, and then reconnect the lower part.
    Voila.
    /forums/images/graemlins/thumb.gif
    Takes me about 10 min
