Replacing The End Of An RCA/Patch Cable
Discussion in 'The Lounge' started by Resurrection_Joe, Dec 27, 2005.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I was wondering why my car's subwoofers sounded weak all the time and then would suddenly pound at certain times
    Turns out the end of one of the patch cabls to the amp is wobblybit knackered something british.... anywho....
    I wiggle it and it works, but it won't stay
    So, do you need special tools to put it on or will my handy dandy wire crimp thinger work?
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    replace it
    or you can solder it, but it wont be easy
  3. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I don't want to take the trim out of my car again though....
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    well you can cut an end with about 3 inches of cable off a spare cable, and just solder the bare wire's together
  5. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    But it will be ALOT easier to just rerun a new wire, since soldering RCA's is tricky
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yep read my first post
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You just buy new ends at Radio Shack , if you can find one with Radio stuff left in it . Cut your ends off , slide the plastic cap on the line , strip the outer jacket off , pull back the braid , strip the inner , solder the inner to the center , take that braid you pulled back and twist together , cut to legnth , and solder to the outer AFTER you crimped it into it , slide plastic cap down to it and thread on . So simple to do .
  8. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Well said, I was beginning to think I was the only guy who made his own rca cables.
