replacing the floor pan
Discussion in 'The Garage' started by adamforsythe, Dec 24, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Are there any GOOD KITS for redoing a floor pan? I noticted that it is about time to redo the floor pan in the good old '86. Plus can I see pics. Plus get some info on the right way to do it?
    Adam
  2. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    what part of the floor? front? rear? companies like LMC have plenty of replacement pans you can weld in. I wouldnt worry to much about having the exact factory style, just make sure u cut alllllll rust out and once weld in.. seal it, and anti rust it....
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I am going to try and replace the whole thing. I might rebuild the floor pan frame if it needs it. I will replace the gas tank and other little things. While I have everything removed I will add rust bullet and paint.
    Adam
