Replacing the oil pan
Discussion in 'The Garage' started by eshorvath, Nov 17, 2005.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    I want to replace my stock oil pan. I believe that the tin, being a bit bent may be causing a little leak near the rear of the engine. I thought it may have beeen a rear main seal at first, but after pulling the inspection plate, everything near the RMS is dry, adn it looks to be leaking from the back of the oil pan.
    I replaced my valve covers with cast aluminum ones, and they have not leaked since.
    Is there an oil pan with the same theory?
    Where can i get it?
    Cost?
    Any ideas?
    Eddie
  2. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    i just did the swap with a 7qt transdapt one... costs me 90 bux cdn funds
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Go to Summit!! www.summitracing.com They have everything from $30 plain Jane pans to $300+ racing pans.
