Replacing the stock gauges
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by opfor2, Jan 24, 2003.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I would like to replace my stock guages on my 90 Blazer. I know it can be done but what must I do? What kind of guages will fit and can I use the OEM sensors or must they also be replaced. I'm thinking of replacing the guages on the left hand side of the dash, i.e. oil, H2O temp, volts.
    Dan...
  2. dremu
    Feb 27, 2000
    15,969
    462
    East of San Francisco
    Well, pull the cluster out to see for yourself. Pull the stuff at the bottom of the steering column, and then the dash panel around the cluster and the vents, radio, etc. You can take out the dash pad but I don't think you'd have to -- been a while since I've done this.
    The problem is the circuit board thing at the back of the cluster drives all the gauges, so you'd need to carefully fold it out of the way for the gauges you won't use. I wouldn't cut it as traces for one gauge might go behind the other ones.
    I spose you could bypass the whole PCB and wire whatever gauges you're keeping factory -- the gas gauge, and your speedo if it's electric? ... I'm used to the older trucks -- directly to the wiring harness plug.
    Anyway ,point being it might be easier to replace the lot all at once.
    Dakota Digital has a slick one, or of course you could DIY.
    -- A
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    How about like this?
    [​IMG] [​IMG]
    Bill
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    For the 40th time:
    Gages
    Just kiddin' ...it's only been 20 or so... /forums/images/graemlins/thumb.gif
  5. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    now that's a beautiful dash
  6. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
