Replacing transmission
Discussion in 'The Garage' started by orangeGMC, Feb 20, 2005.
  1. orangeGMC
    orangeGMC 1/2 ton status
    Dec 26, 2004
    184
    Connecticut
    I am going to be swapping out my TH350 for a rebuilt one. I would like to know if there are any gaskets that go between trans/engine and trans/adapter and adapter/transfer case? I have a 350 with TH350 to NP203. I don't want to get my hole project held up over something as simple as gaskets. Also does anybody have a parts breakdown diagram?
  2. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    there arent any gaskets between the motor and trans i know for sure but not sure if there are between the adapter.
  3. red77blazer
    red77blazer Registered Member
    Feb 13, 2005
    47
    Washington
    Technician a says
    there is a gasket between th t-case and the adapter plate- some guys use silocone, there is an o-ring that goes in the back of the transmission and the adapter plate and nothing between the engine and transmission.
  4. orangeGMC
    Dec 26, 2004
    184
    Connecticut
    Do you know if local parts stores would have these? Or part numbers?
  5. red77blazer
    Feb 13, 2005
    47
    Washington
    any good transmssion shop should have them and know what your talking about right away
