Replacing VENT window seal?
Discussion in 'The Garage' started by fortcollinsram, Dec 1, 2003.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I am fed up with with the leaking and whistling being louder than my radio and my dual 3" flowmaster 50s and 454 on the highway. So I went and bought the 1-piece GM replacement seal...only probem: I have NO clue how to remove the vent window to allow me to replace the seal. Any pointers or step-by-step instructions or diagrams would be great....Thanks gang...
    Chris /forums/images/graemlins/thumb.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I'm 99% sure that I posted a diagram of how the vent window comes apart, about a year ago. You'll have to search for it though, and no garauntees on if the link is still good...
  3. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    Once the door panel is removed, I think 1 bolt holds it in place.
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    There's a bolt on top of the doorframe too.
  5. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    My vent window leaks real bad becuase the lock is coming apart and it doesnt hold the window closed tight? any ideas on fixing that?
  6. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    had same problem...ordered seals for both sides, looked the job over and just ended up ordering a new vent window assembly for the driver side. Never did change the passenger side. It involves popping out the old rivets, and installing with new ones.
