replacing wheel bearings...is there a more detailed how to?
Discussion in 'The Garage' started by 77Jimmy, Jul 17, 2003.
  1. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    I'm about to undertake a front wheel bearing replacement (assuming their toast) for the first time. Need to make sure everything is solid and straight before I put on my new meats and wheels. /forums/images/graemlins/grin.gif
    The Chiltons and Haynes don't have enough detail for me, so I bid and won a service manual on ebay which hasn't arrived yet. I'm hoping this has a lot of detail w/ pics...my question is does it? And if it doesn't, where can I find something that does? Sorry for being an idiot guys and dolls, I'm at the bottom of the learning curve. /forums/images/graemlins/frown.gif
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Im not sure where to get you any info But it really is pretty easy. Ill recoment AUTOZONE strongly for the bearins TIMKEN is good stuff(napa's expensive ones are pretty nice too) One of the bearings should come with the race Ill also recoment getting the other race and ofcourse the seals
  3. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    I know this isn't exactly what you need, but there are some pics and some steps that you will need to follow to tear it down.
    http://coloradok5.com/8lugconversion.shtml
    As for better instruction, I found the haynes to have all the info you need. If you've replaced the auto hubs, the hardest part of the whole job will be getting the outer lock ring off. Between mine, and 3 or 4 of my buddy's that have k5's, I've repacked the bearings a 4 or 5 times now and that damn ring that comes with the Warn Premuims still gets me.
  4. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Bend the ends of the rings slightly on the Warn premiums. Mine pop right out with a small screwdriver.
  5. gruveb
    gruveb Registered Member
    Jun 26, 2003
    51
    Rio Rico, Arizona
    Spend an extra $20 for one of those nifty bearing grease devices. You put the bearing in there, and then pump it up with grease. I hate going through 10,000 rags only to have one slip out of my hand and pick up every spec of sand in the zip code.
  6. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    Recommendations
    I admit it...I havent done a wheel bearing replacement on a 4WD vehicle ever in my life. Does anyone have a bearing mfr they recommend? I have looked at pictures of the wheel bearing and they are way different than a car. Thanks in advace for the help....
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Timken, from autozone.
  8. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
  9. docgab
    docgab 1/2 ton status Premium Member
    Oct 1, 2002
    1,166
    Medford, OR
    I just went through this job this week. First, the bad news; I have a factory manual and it was not anymore detailed the my chilton's. Now the good news; it really isn't that bad. I am way at the bottom of the learning curve and have a tendency to scare myself into not getting the job all the way done before chickening out and trying to find someone else to help who knows what the hell the are doing (thanks Craig!!)
    Follow the directions in the book and lay it out in the order it came out so you know how it goes back. My outer bearings came with bearings and race (thanks again Craig! lol) and the inners I had to buy the bearing and the race seperately. I went with Timken brand. I knocked the races out myself but had them pressed in by a local machine shop.
    Just get into it and post up here if you get stuck. Lots of people to help. Drop me a line if you need help from another noob who went through this job. :grin:
