Replacing Wheel Cylinder in 14B FF - Any Special Tool Needed??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Dec 4, 2002.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I have a 14B FF 1 ton rear and I need to change one of the brake wheel cylinders. I have the tools to do my original 10 bolt....will these tools work for the 14B or do I need to get some special tools.
    Also, are there any special tricks or are these just your basic drum brakes??
    Chris
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nothing fancy except for a flare nut wrench and I think a 7/16" combo wrench for the two bolts that hold the cylinder to the backing plate.
    Of course, the flare nut wrench is for the brakeline. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i had two on the rear of my ol' 10 bolt, they managed to "lock" themselves on there, didnt want to let go, i had to mutilate the bolts to get them off, they were a PITA, but autozone had em for about 10$ a peice, not bad knowing that that part of my rear brake worked. chisel and cutting tool was used, and a BFH was used too. and if you didnt know already, id put some never seaze on the new bolts you use on the wheel cyclenders so they will come off easily next time you blow one. good luck /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
