Replacment Stock Leaf Springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric, Oct 16, 2000.
  1. Eric
    Eric Registered Member
    Mar 21, 2000
    86
    Thinking of doing a little suspension work. Looking to improve overall ride quality and quite things up a bit. Suspesion is really ratteling over bumps and holes.
    Where is the best place to get replacement springs? I have no lift. Anyone purchased them from LMC? Any suggestions or installation tips greatly appreciated.
    One eyed super fly- watch out!
    86 K5 Blazer
  2. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
  3. Eric
    Mar 21, 2000
    86
    Any idea what is causing all the ratteling? Do the bushings go bad?
    86 K5 Blazer
  4. sosamantx
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>Yes, all bushings do wear out. If you suspect the bushings, look inside the eyelet of the leaf spring, where the bushing is, and you can probably see where the rubber is deteriorating. As far as the ratteling is concerned, you just need to look around at stuff, I have a hanger that is broken and the exhaust makes this ratteling sound going around corners. I would look around at all of the bushings, shocks, sway bar, etc. - Steve :)</font color=blue>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
  5. Eric
    Mar 21, 2000
    86
    Just looked and found a broken leaf spring in the rear. Should this be replaced imediately?
    86 K5 Blazer
  6. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Yep. Would not drive it until you get it replaced. If you have to, don't take it to highway speeds. Depending on which one is broken, it weakens the whole spring pack. If the one breaks that holds the springs to the shackles, then the whole vehicle can settle to one side abruptly and cause damge to the rear end, sheet metal possibly and cause you to swerve or loose control of the vehicle. I would replace all the bushing with urethane ones. Will make it 200% better. May want to look at aftermarket with a mild lift unless you want to stay stock. Pro Comp makes a 2.5 in spring for the front that are tougher than the stock springs. I know Superlift makes rear springs, not sure of the sizes though.
  7. Eric
    Mar 21, 2000
    86
    How do the poly bushings help? Will the rig handle better? I assume that they do last much longer.
    86 K5 Blazer
