Repositioning shock mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 45acp, Jul 28, 2001.
  1. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    How do you determine the length of extension of the shock when you relocate the top mounting? I have read several posts on this subject and it is never quite clear how this demension is determined. I have the body off and only the axles and springs on the frame at this point so it easy to access everything. I have the Ford shock towers for the front and will build a new crossmember type support in the rear. I want longer travel and just want to know how to set the length of travel.
    Ride with pride,
    Bill Hughes
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    To be honest I just guesstimated and it turned out to be right on. I get full droop and stuff front and rear w/o coming close of bottoming/topping out the shocks.
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  3. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Is the drop greater than the compression when measured with everything setting flat?
    Ride with pride,
    Bill Hughes
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    there is a article about that in the product reviews section. might help
    We are surronded. That simplifies our problem.
