Resetting the brake light?
Discussion in 'The Garage' started by Pookster, Mar 5, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    did a search, came across something close to it, but nothing about acutally how to reset the brake light-. 92 k2500, blew out a hard line, light came on. Replaced the hard line and what not, but cant get that light to disappear.
    Someone point me in the right direction? /forums/images/graemlins/1zhelp.gif
  2. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Disconect the battery for a min. this should reset the light /forums/images/graemlins/thumb.gif
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    If that doesn't work disconnect the the top plug from the black box next to the mc, turn the key on, but do not start, for 30 sec, shut off, reconnect the plug, should clear the brake light.
  4. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    also on the front there is a black cover that behind it is a pin that you can push in to turn it off also...IIRC it is on the Proportioning valve front below that wirer plug
