results of the first trip out.
Discussion in 'The Garage' started by gmcjimmy4x4, Nov 6, 2006.
  1. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    Well took the long awaited first trip out after doing alot of work.(arb's, 37's rear disc' transfer case rebuild and short shaft sye) Alot had changed since my last outing. I guess it wasnt enough though. I greatly under-estimated the popular Fordyce Creek Trail (sierra trek). After breaking a lift block caused a broken u-joint. Then in 2 wheel drive i ended breaking both front axles in seperate incidents. From then on it was winch only untill i had a u-joint hiked in 2 miles. Still with 2- wheel and winch it took a long day to get it back to pavement, where i had to have it towed home.
  2. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    any pics? and what did you break u-joints and axle shafts on? rocks, mud, etc?
  3. gmcjimmy4x4
    May 6, 2005
    132
    Sacramento, CA
    Broke the ujoint when the likt blocks startewd to break out and rotated the whole axle upward. Then wihtout rear drive breaking the front axles was inevitable. It was all in the rocks though. Ill try to ad some pics soon.
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Next mod: Ditch the blocks and shackle flip it. Pretty cheap and that whole incident can be avoided. Sorry to hear you broke so much on your maiden voyage though.:doah:
    -Harrison
