Retarded parking brake
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Aug 25, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Sometimes when I go set the parking brake, its like it takes no pressure to push it down and then it will slowly rise back up. Other times it works fine. I feel like a retard when I go to set the parking brake and the damn thing pops back up.Thanks.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  2. Sounds like a cable is binding up,or the spring in the pedal
    assembly is going bad.Take all the cables loos and move them indevidualy,to see it one is binding up.If so LMC sells all of these cables.
    Hope this helps,good luck.
    IF IT AINT BIG IT AINT BAD!!!!!!
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I have the same stinking problem with mine. I got the shop to look at it and they said that I had a brake line that was shredding and bulging in the sleeve. Got the part from LMC. Its worth it.
