rethinking wheel size...16" not cool?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Feb 9, 2002.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    rethinking wheel size...16\" not cool?
    when I go 1-ton I am gonna need new 8 lug wheels. I was thinking of going with 16" steels. They are lighter than 16.5s (a little anyway!)...seem to hold a bead well... and are large enough to fit a D60s junk in (otherwise, I'd stick with 15s!). 1 problem...every time I see a set of tires I'd like...they arent made in the size I want for 16" rims!!! =( What is up with that? is a set of 38x14.5x16 (or close to that!) SSRs to much to ask for??!!? I'd like to hear from peeps running 16" wheels...whether they think it was a good size to go with or not. Any input appreciated.
    J
    ps:if the guy who runs interco is a ck5'er...hook me up! ;)
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    Re: rethinking wheel size...16\" not cool?
    <font color=blue>You can fit 15s on a D60.
  3. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    ya I run one ton gear and 15's. For tire options you really need to. Isnt 36" the biggest 16" they make? Just like everyone I get tire sick. I started with 35s, then went to 36s, now 38s, next will be 40s, I don't want to limited at all. Id say give 15s a try even though appearance wise they aren't as good looking.
    1986 GMC Jimmy 6" springs 3" body, 38/15.5/15 Swampers, 14-bolt FF rear, Dana 60 front, 1991 front-end.
  4. bigredblazer
    bigredblazer 1/2 ton status
    May 10, 2001
    170
    western slope
    Super Swamper SSR 37x12.5x16, they also make a 38x13x16 Swamper bias ply. I can get either one for you for less than advertised!! The 38's have the height, but I would go with the SSR's for the street, plus they are great off road. Other wise get your grinder out and go with 15" wheels. Jon
    Blazin' Trails ORD Style
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Jon (bigredblazer) gave the best choice you can get with SSR's with the 37" size............I run 35" SSR's in a 16" rim size. More and more sizes are coming out regularly. I'd go 16 if I had to do it over again. There may not be as wide a variety of tires out there in 16's as 15's or 16.5's, but there are enough. Beats grinding calipers in my opinion.
    ONE TON</font color=blue> <font color=green>TPI'd</font color=green><font color=red> BEAST<font color=red>
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, if I could stay with 15" wheels...I could keep my current tires post-1-ton-install....just get some new 15x10 steels... that'd make things a LOT easier. How much grinding do ya have to do to fit the D60 inside steel 15 inchers? anyone have pics of this process? I am clueless... are there safety issues with this? I don't wanna do anything unsafe or anything...but I could be runnin' 1 ton _way_ sooner if I didnt have to get new tires and all that jazz....
    J
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    How about <a target="_blank" href=http://members.home.net/russhuffman/grinding.html>this</a>?
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    sweet! =) man, keeping 15" rims would be awesome. I could keep my current tires (35x12.5x15 ProCompMTs with about 85-90%) and just get some nice and cheap black 8lug steels. Thanks much for the super-informative tech info! ;)
    J
  9. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    awsome article russ
    now if you could make shimming my front 10 bolt in to alignment that easy you really would be "da Man"
    very cool
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  10. project84k5
    project84k5 Registered Member
    Sep 14, 2004
    40
    Fort Worth, Texas
    ssr's
    super swamper makes the ssr in a 38.15.50.16 which easily fits well on a 16X10 wheel, thought the 4.25" backspacing might suck a little though
    later
    ryan
  11. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    brought back from the dead....old post
  12. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    if you wanna spend about $300 you can run most any 15" wheel with no grinding. this guy http://www.screaminseeman.com/home.php sell caliper brackets that will allow you to run 3/4 ton caliper and rotors on you 8 lug D60.
    the brackets are $90. then you gotta buy calipers and rotors and you should be able to pick all that up for under $200.
    this is the route i chose to go. but then again i needed new rotors and calipers on my 60 anyways
  13. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    why not run 17's? this is going to be the new 15" wheel i think.
  14. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    lol what is with all the old resurected posts.
    :bow:
  15. nmud2deep
    nmud2deep Registered Member
    Apr 23, 2003
    63
    georgia
  16. nmud2deep
    Apr 23, 2003
    63
    georgia
    my blazer is the first in the line-up...''nmud2deep'' 86'k5
  17. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    The original post here is from 2002, :eek1:
  18. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Jekbrown, I think you would be happy with some 22's and some 49" Irok's :haha:
  19. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Me thinks someone *cough*project84k5*cough* just bought a new WayBack Machine. :eek1: :doah:
  20. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Dude, might want to check the date of the post you just replied to............
