retrieve shift deleted files
Discussion in 'The Lounge' started by BranndonC, Jan 26, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    anyone know how to retrieve files accidently deleted with shift delete?
  2. lady bog
    lady bog 1/2 ton status
    Nov 12, 2003
    231
    Illinois
    You might want to try the search with Windows Explorer. It may be there but then again.. it may give you false hope. It will probably show up and then say that you can't view it because it's been deleted. I dunno try anything I guess /forums/images/graemlins/thumb.gif
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    What OS?
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    windows XP
    thanks for the idea i'll search today
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    You might have to use like Nortons to pull a deleted file or a similar tool like that.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The files are still there, it's just that the first character in the file name has been replaced with a special character that the file system ignores. Check on someplace like www.download.com and you might get lucky and find a freebie tool to recover the files. If not, then Norton Utilities will recapture the data for you, provided that it has not been overwritten since the time it was deleted.
    Now, here's the bad news... The more you use your system after a file is deleted, the greater the chance that the file, or parts of it, will be overwritten as the system writes new data to the drive. Once a file is marked as deleted, the system is free to use any of the sectors that contain all or parts of that file. And running a tool like Disk Defrag will almost certainly overwrite the file as it reorders data on the drive. /forums/images/graemlins/eek.gif So if you have that set up to run automagically, turn it off until you recover the lost file.
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks guys, re-created the file again, but in the future i will use these tips. Thanks a bunch /forums/images/graemlins/thumb.gif
